spoonmectr »
https://forums.nicoclub.com/spoonmectr-u46387.html
Sat Sep 02, 2006 7:07 am
Ive got a 97 Maxima that wont start. It cranks normally, except while its cranking the RPMs drop to 0, then it picks back up. Ive checked the coils and condensor and replaced the plugs. Ive also cleaned out the throttle body and IACV valve. After ive cranked it for sometime if I pull a plug it as fuel on it. The check engine light is on and it has the following codes, 0803, 0201, and 0503. Anyone have any ideas. Is there something that typically goes wrong on these cars? One of the codes is for the FR oxygen sensor, would that keep it from starting? Occasionally I will get it to start after consideralbe effort, then the car runs fine. But as soon as i shut it off, it wont start again.
spoonmectr
