97 maxima se 5 spd sensors help!!!!
Blanco203
Car: 97 maxima se
I have a 97 maxima se 5spd.Had a slight hesatation problem in 3 rd gear and also in 4th gear.Then my clucth was also slippin in 4th also 5th gear especially noticable on hi way during acceleration.So i went ahead and replaced the clucth with a OEM replacement clucth.The new clucth was installed and imediatly check engine was on.The car is really hesatating in all gears now like it chokes on acceration.Took it to a local shop for a diagnostic and Mass air flow showed,knock sensor showed also bank1sensor showed.All of those sensors were replaced and check engine is back on its now readinf crank shaft sensor and still hesatant and boggy in all gears 1000$ later and problem still not solved.Anyone can point me in the right direction?Will this sensor the crank shaft sensor solve the heasataion and bogs? really bad uphill HELP!!!!
maxhopper
Car: 02 Maxima SE 6spd
FYI in the future, please start a new thread regarding a new question. I split this out of the unrelated thread it was posted in.
Thanks.
As for your question, a bad crank sensor will make the car run horribly. There are two crank sensors, so make sure the correct one is replaced.
