NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sun Jun 26, 2005 6:17 am
If you cant determine if its a vaccum leak using carb clean, try removing the drive belt for the P/s pump and see if the noise is gone. I have heard many A32's with slightly excessive pump noise. If that is not it try removing the main drive belt and see if the noise is gone if it is gone it could be the Alt or Idler/adjuster pulley. The altenators tend to make noise as well. If I am not mistaken the 97 max had a recall on the altenator as well. If you trace the noise to the altenator find out if the recall has been done on your car. If not, free repair . If you post your vin I can run it to see if the recalls been done.
