coolhand »
https://forums.nicoclub.com/coolhand-u34947.html
Thu Mar 23, 2006 7:20 am
I have. It is not that difficult, but you need the right tools. You will have to remove the alternator belt tension pulley and mounting bracket. Next the A/C needs to be unbolted from the engine(you do not have to disconnect the A/C lines from the compressor) and there is a A/C line bracket above the alternator that needs to be removed to allow the A/C unit to dangle for the removal of the alternator. There is a bracket on the top of the alternator that needs to be removed to ease the removal and install. The rest(if you know your way around cars) should be straight forward. Hope this helps.
