, does anyone out there done their job with pictures or directions ?mtcookson wrote:Moved
Isn't the ecu in the 5.5 gen a learning cpu where it will change air/fuel to optimize performance. I noticed after installing my cai that it seemed to get better over the course of a few long drives... is it just me or does the ecu adjust itself. So what I'm saying is if you dropped in just a bigger housing the ecu would reconize more air and automaticaly adjust the fuel to match the air and using a safc would further optimize perfomance.DaveVQ wrote:It has been dyno proven that there is a 10whp gain to be had when doing this when NA...on a 3.5, you can gain about 7 whp on the 3.0, but it really depends on the kind of tuning you are after.
all cars can make adjustments to a point, your car obviously notice the increase in air, so it adjusted to a point. But with this mod will require an AFC to tune it out and make the proper adjustments so as not to hurt your engine or even blow it.johnnyd6404 wrote:
Dave , didnt u read my currently post about the guy who makes maf ....I still need email to get ahold of him thanks.Too fast 4 you wrote:awesome , i think i ll go to that direction and makes me much more easier than doin more work on another maf.
I have some problem to log in . is there any way i can get ahold of him like via email or something else like that.
thanks
I bet that's where the most of the power gains come from... not to say its impossible to get gains from a MAF swap. I have actually heard of someone making the housing larger using the same sensor with a turbo setup and actually tuning it that way but that was with a turbo setup so is a bit different.DaveVQ wrote:by changing the maf housing and retuning
