97 KA24E rocker/lifter noise
mre5003
Car: 97 Nissan pickup
I have 97 pickup with ka24e with lifter noise, I can do the leak down procedure and it will stop, drive it for a few miles about 50 and it starts again..I had the motor changed and the old one had the same problem but much worst. the newer motor came out of a 2wd, mine is 4wd so we had to use the same front cover, oil pan and oil tube..I heard that a cracked tube will cause this..any help would be appericated
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Its possible that a crap oil pickup would make your motor louder.
Are you losing any oil? not leaking but just missing somehow.
mre5003
No the motor doesn't use or leak oil. It sounds like it is only one rocker making the noise, could it be a rocker that just won't stay pumped up? Thanks
