97 ka no fuel?
90ka24de
Car: vRRooommm
my 97 ka isnt getting any fuel to to motor? i pulled the fuel line off to see if that was the problem.. any idea of what it would be? fuse?
niznos
Car: 03 Z-track, 98 Maxima GXE, 90 240SX RIP
Always start with the simple stuff. Do you have gas in the tank? That sounds like a stupid question, but seriously, the gauge could be bad and you are out of gas. There IS a 10 amp fuel pump fuse. Check that. When was the last time you did a fuel filter change? It could be plugged up. The fuel pump could be bad, so have someone stick their head in the trunk and turn the key to ON, and don't start. The guy in the back should hear a "whrrr..." for a few seconds if the pump is working.
navysnail
did it stop all of the sudden or have you been working on the fuel system or anything else like that
is the fuel line geting pressure?
Dattebayo
It really probably is the fuel pump; where is the fuse though? Happens to alot of people and its not hard to fix really. The hatch for the pump is in your passenger side of the trunk. It only suxx if you have a full tank at the time (dangerous).
niznos
fuel pump fuse is in the fuse box under the hood on my 90. Should be the same on the s14.
90ka24de
Car: vRRooommm
i have a half tank of gas from the ten dollars i put in.. i'm also thinking its the fuel filter or some fuse or relay that went out... i'll check it out and see what it is.. thanks
