94J30 wrote:Check the terminals for corrosion, also is the battery sealed or will it take distilled water?? If so, it may be low on water. Just a thought.
Yes, I had this exact same problem with my 95 j30. if the terminals do have any corrosion on them at all, the j may hesitate startup, you can get a terminal brush at places such as Ace hardware, and the auto parts stores. Takes about 3 min to clean them off and the jshould fire right up.
That is, if your battery has a full charge, so if you have a battery charger just put it on for a few hours.
