rgstealey »
https://forums.nicoclub.com/rgstealey-u254917.html
Tue Aug 11, 2015 6:24 pm
This may be a good one for you electrical gurus. Sooo...quick history on starters I've been through...
Bought car at 159k. Oem starter was fine but my dumb*ss broke the now-brittle solenoid cap sooo got a reman. Ultima starter. We'll call it Starter 1. Starter 1 lasted about 3000 miles and then the solenoid leads shorted internally (a la my other post 'starter constantly powered'). So exchanged it for starter 2. Keep in mind now that no fuses have blown, relays checked out with the DMM, and proper voltages appear to be going to the right places. Starter 2 works for about 20 miles. Think I used it 4 times total, and on my way to work, I believe it must have engaged and stuck to the flywheel because their was a whirring noise and I believe it burned out because afterward the starter was straight up dead. Towed back to house, exchange for starter 3. Install starter 3, car starts. clackety clack. The starter gear never returned inward. Pull the thing off, and instead of the 'twist up, twist down' movement, the gear was separately spinning freely at the end of the housing, apart from the apparatus that would normally bring it back in. Can twist it back down, but only does same thing when trying to start the car. I am STUMPED. No codes, no fuses blown, nothing out of the ordinary that I can find. Am I just getting horrible luck with Ultima starters or did I miss something? Please help!
