I had check engine light and car would not have good acceleration without constant holding foot to the pedal at all times. Mechanic said, replace throttle sensor. We put it on and drove the car for approx 10 min. Ran just like it should. Went back to the shop, I paid, and turned the car on and would not even start. He adjusted the screws and it would run, but, said, in order for it to keep running the idle was not in range according to specs. I drove the car while it was not in range but would keep running. When I turned a corner the car would die. Brought back to the shop and he kept making adjustments to screws. Finally, I said, I don't care if in range or not, I have to keep the car running in order to drive. This is where I am at. It is out of specs, but, does run. Still no power in acceleration without pressing on pedal at all times or it immediately drops acceration down too quickly. Sometimes at idle it will bump from 1100 to 1800 rpm. Other times, it won't. I purchased the car with 145K last year and it has always had strong exhaust smell. There is no cod
e or check engine light on currently. Latest update from mechanic is probably wiring issue. Please help! My son is leaving for college in 2 weeks and the car has to be reliable.
