'97 J30 fault questions
Jettech
Car: 1997 J30
Two weeks ago I bought a '97 J30 that is in great shape and I love the car. About 800 miles later I was accelerating onto the freeway and the engine hesitated for a split- second and the check engine light came on. It's been a couple of days since and no more hesitations. I had the OBD read and three fault codes came up: P0120, P0732, and P1705. Since it seems to be running fine should I reset the faults, change the throttle position sensor, or take it in for deeper diagnostics? Any advice please.
Also, any advice on acquiring a service manual for this vehicle?
yodawill2000
Car: 94 Infiniti J30
120 = TP sensor732= AT 2nd Signal1705 = TP Sensor AT
Jettech
Car: 1997 J30
I got those but thanks. They all seem related to the throttle position sensor - that's why I was wondering if I should change that or if this was a one-time glitch that I could get away with resetting in the ECU...
yodawill2000
Hang tight , Im sure a J30 guru will chime in soon.
gr8scott72
Car: 1994 Infiniti J30t
Jettech wrote:I got those but thanks. They all seem related to the throttle position sensor - that's why I was wondering if I should change that or if this was a one-time glitch that I could get away with resetting in the ECU...
Well, reset it and see.
driverdriver
Car: NICO's longtime resident Canuck!!!
I had that happen once in I think 1998 or 1999. Brief hesitation and engine light flickered. Never had it since. I did take it back to the dealer. They couldn't find anything. I attributed it to bad gas. I had filled up at an out of town dealer where I had never bought gas before (or since then).
Jettech
Car: 1997 J30
Update: When leaving work yesterday I had trouble starting the car - it would seem to start but would stall immediately. I had to use the gas pedal for the first 15 - 20 seconds to keep it running then it was fine. I guess I'm not going the fault-reset route.
I called around and there's only one place around that will work on it because one of the fault codes reads Manufacture's fault. I found a site that has a throttle position sensor for about $100 so I was thinking I'd check the wiring and then change it if the wiring seemed okay.
Since I don't have a repair manual and this car is new to me, can anyone tell me where it is and what specifically to check for?
Thanks
yodawill2000
Its on the drivers side front of engine.Right where the intake tube meets the Plenum(Intake Manifold) , you will see a little box mounted on the right side with a cable going to it . Not sure how to test it but it looks mighty easy to replace.I'll see if the FSM shows how to test it .
yodawill2000
shoot me an email at [email protected] and I will reply with a pdf showing the test procedure .
Jettech
Car: 1997 J30
Thanks, I just did. Did you get it?
yodawill2000
Yup ..Its on its way . 5 meg+
Jettech
Car: 1997 J30
Got it.
I just remembered that I changed the air filter the other day - put a K&N in it. I wonder if I knocked a wire loose or something. Maybe I'll get lucky.
Thanks.
You know, I was looking at an ES300 and the J30 and this forum helped me make up my mind. I had a "support group" like this when I had my V-MAX and it was a huge help when I needed support.
Thanks again!
Jettech
Car: 1997 J30
It looks like that section covers the wiring, ground and power but not the actual sensor. It says that is covered in Electrical Components. Do you happen to have that section or should I assume that if it isn't wiring then I need to change the sensor?
