Post by bq7458 » https://forums.nicoclub.com/bq7458-u88404.html Mon Feb 04, 2008 5:01 pm
Post by gr8scott72 » https://forums.nicoclub.com/gr8scott72-u37410.html Tue Feb 05, 2008 6:38 pm
Does the car turn over like normal? Sounds like you have a bad starter maybe?bq7458 wrote:Hello,
I need help with my 97 J30 which burn the ignition fuse when engine started about few seconds. The door light, high light, brake light and horn still work, but radio, turn light, windows, instruments panel and starter do not work any more.Everything will be working if do not start engine while put on new fuse.
Thank you for help,
Bobby
Post by bq7458 » https://forums.nicoclub.com/bq7458-u88404.html Wed Feb 06, 2008 2:54 pm
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
