jltibbs »
https://forums.nicoclub.com/jltibbs-u32412.html
Mon Mar 30, 2009 3:15 am
Welcome to NICO.
As far as the noise is concerned, could you describe it a little more. I understand it is loud, but is it a pop, bang, squeal or some other type of noise?
On the axle, the only thing I recommend is to get a new seal where the axle meets the transmission; be sure to get it from the dealer.
The knock sensor is located dead center of the block under the intake manifold. It can be replaced with an extension, a 'knuckle', and a 10 or 12 mm socket. Removal of the air intake tube may be required if it is stock.
If you have anymore info or questions, feel free to ask.
