GCON7 »
https://forums.nicoclub.com/gcon7-u223610.html
Tue Aug 06, 2013 5:51 pm
I recently purchased a 1997 HB 4X4 KING CAB, 2.4L, 5-spd, w/appx. 135K. The engine was removed, and I was told it was shot (BAD). I got a 2.4L w/appx.130K. The new engine needed guide repair. I swapped the oil pan, intake, and completed the guide repair. I got it all back together, and it would barely run. I would have to pat the gas to keep it running. After hours and hours of investigating, I realize the oil pump is off 1 notch. With the pump finally installed correctly... same result.
Here is a list of symptoms:
HARD TO CRANK
WILL NOT IDLE
SLIGHT GAS SMELL WHILE RUNNING
PLUGS SLIGHTLY WET AND SMELL LIKE GAS AFTER RUNNING
LOUDER THAN NORMAL LIFTER NOISE
Here is a list of things I've done or checked ( I DON'T HAVE A MULTIMETER OR SCAN TOOL ):
COMPRESSION CHECK ( ALL CYL. ARE BETEEN 142-152 )
CHECKED TIMING MARKS
CHECKED FOR SPARK
CHECKED INJECTORS
SWAPPED MAF SENSOR (NO CHANGE)
TRIED DISTRIBUTOR OUT OF MY 96, THAT I KNOW RUNS GOOD (NO CHANGE)
REMOVED AND CLEANED ROCKER ARMS
If I am forgetting anything I will update.
If anyone has any ideas or suggestions, I would greatly appreciate it. THANKS IN ADVANCE!
GCON7 on Wed Aug 07, 2013 5:00 pm, edited 1 time in total.
