(97-FY33)Went to Dealer today and I have NO SERVICE RECORDS on file What Next
NyRider
Car: 1997 Infiniti Q45
Took the Q to the dealership today to see a Mr. Mark Carson - Assistant Service Manager... gave him the vin expecting to recieve a service record report and what..... even to his surprise There was NONE
now when i bought the car from the lady in Iowa she gave a big yellow dealer record book with unfortunantly ended @ 71k miles
now I know I know now after joinging this site that the #1 priority when searching for a car should of been up-to-date service records ect...
but now im stuck and upset what can I do to retrieve those detailed records????????
Mr. Carson told me that sfter so many years of not bringing the car to the dealership infiniti will drop the service records/car form thier computerson another note====anyways I trotted over to parts to check how much they were stinging fy33 customers for the suspension parts I ordered from joe and just have to say Thank you for infinitipartsusa.com as I am a permanent customer. I also got this diagram for the front suspension Im sure you've seen it beforehere it is for fun I guessthose circled parts by the way are the parts that the service department said I should change to improve my suspension I smiled and said yes yes good good.... but I got the list from you guys dont worry bushings, bearings, end links, ect...HEHE
99q45t_vl
Car: Grey 2014 QX60
Dark Green 99 Q45t - gone
Ask Joe, there is a chance he'll be able to help you w/ the service records.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
NyRider wrote:Assistant Service Manager... gave him the vin expecting to recieve a service record report and what..... even to his surprise There was NONE :
Infiniti merely archives them, so it might take a day or two for the Service Manager to get them from CA. If you have all records up to 71K, then not much else may be gleaned unless it has seen a dealer since then.
NyRider
well let me see if I can explained this... As I go about replacing suspension parts I came to notice that my driver side strut mount the (new) one is totally diffrent from the strut mount meant for my 97 q45 internally.... I dont know if its from a first generation or from a q45t ect...here's a pic of the correct oem one:
here's a pic of the replacement -not by me hence the need for records(new)one:
I know you cant see the diffrence really but the replaced one has an inside full of rubber from top to bottom unlike the oem which has a grove which I can run my finger long the inside? I dont know if its a good descriptionthe grove is by the rust on the picture as the other has no grove at all what you see is what you touch
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
I'd replace both anyway, so records not needed here.
NyRider
yea I winded up ordering both anyways will take pic's ect.. when I do the write up.
While on this subject I hav read replacing strut mounts, ect... what I can on this site but am still confused as to whether I need to compress the springs when removing the strut to replace the mounts and cartridge
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
yea you do. look for my writeup.
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
When I replaced the suspension in my 00, many parts were slightly different.
Parts do change. Ordering the original part # from the dealer 7 years later does not mean it will be identical in looks....but it will in function.
Q_SHIP
Car: 1999 Q45T with a billion miles.
Springs do need to be compressed for replacing the cartridges.
