lucky03602 »
https://forums.nicoclub.com/lucky03602-u20182.html
Mon Jan 12, 2015 6:00 pm
having a hard time figuring out what this one particular broken part is called. looked on here and google for diagrams and lists of parts and have come up empty.
97 d21 cal emissions. replaced vent valve on the canister (canister had a slight crack from undoing the old valve so some hot glue and hope its sealed!!) while putting it in I noticed a part is broken on a different piece.
on the back of my truck attached to the frame is my canister. not including the valve there is 2 hoses coming off the canister directly. the smaller one goes to a white vac splitter of sorts. this white splitter has 2 very small hoses that go towards the back of the truck and connect to this piece that also has an electrical connection.. this piece is what im trying to name and figure out it's purpose.
where the 2 hoses attach to this piece is a short piece of plastic that seems to be glued (at best) to the metal part.
please help if you can figure out what I mean. trying to get this dang this with no cel for a sticker
