97 Auto transmission stuck in park..
Arsenal
Yes i know I posted in the turbo forum which is the wrong one, sorry to anyone who got offended at it.It is a 97 Auto transmission which you cannot move from park, the engine starts fine and runs like normal, you just can' t move from Park.Any help would be grreat, Thanks alot.
Mayhem_J30
Car: Ummm...My Car
you parked on a hill or at an angle?
nisstek
Car: S14 w/S15 SR SOLD, S13 Coupe, 04 Titan, 1991 300ZX, 03 Max
Can the shifter button be pushed in?
Arsenal
Well when we srpay brake cleaner around the white box it works?On a flat surface, we live in Fl, no such thing as a hill
nisstek
Spray brake cleaner around the white box???? Where is this white box?
yellow_jacket
Car: 95 240sx
Are your brake lights working? The car I believe has an interlock on the shifter that runs off of the brake light switch. Basically if you don't put your foot on the brakes, it won't let you shift the car out of park. If you get lazy and just want to drive the car for now, remove the center console and look for the piece that is not letting it shift. I can't really explain to y ou what it looks like.
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
What kind of car is it????? I had my 92 Q45 not move out of Park either unless you pushed the little switch. Turned out to be the same fuse that is for the brakelights. Replaced the fuse and than it worked like a champ. Also, you have a sensor in the brake pedal that releases the transmission, but check your fuses first.
Just another 240
yup, most likey is the neutral safety switch, the sensor that everyone just talked about. OR your transmission is stuck.
