Hey guys, forum n00b here. Many googlings have led me to believe that this forum has plenty of expertise, which I am in great need of...
I searched the forum, and sifted through about 20 threads that looked like they might be relevant, but didn't find exactly what I'm looking for. I found these threads, which gave me some good ideas, but I'd like more input before I head back over there to check out the car:
zerothread/285129http://forums.nicoclub ... ead/285129
Anyway, I'm checking out a friend's car for her, and here's what she told me (in as much detail as I could get from her). The car overheated, and she was able to get it home. She popped the hood, and noticed a crack in the rad just below the filler neck. The next day, she came out to start the car, and it would turn over, but wouldn't fire. I went to go look at it today, and saw the crack, and here is what I noticed with minimal troubleshooting:- Turns over (not seized)- All ignition-related relays are in proper working order (as far as I can tell)- Has spark- Distributor rotates while cranking (pulled the cap)- Fuel pump is operational (checked for pressure)- When attempting to start it, it almost kinda sorta jumps or fires at a certain spot in the revolution, but it's very slight.
Another one of her 'mechanic friends' took one 60 second glance at it and told her it was the 'timing belt'... As far as I know, this engine has a timing chain (not a belt), and I believe it's an interference engine... Also, please note that the car was running, and then turned off, so it wasn't any sort of catastrophic meltdown, like what might happen if the chain broke.
So here are my questions, since I'm not 100% familiar with this particular engine:- The check engine light has been on since about March of this year, so are there any particular ignition-related sensors or modules I should check?- Has anyone else experienced something similar, and if so, what was the outcome?
Thank you guys so much for your time.-Paul
