Timothy S wrote:I put a new pcv valve in my Altima for around $3 plus shipping from Rock auto. $10 should be enough to check that out. The egr code may come from bad vacuum hoses and again that is not an expensive fix. Hoses go for around 70c per foot at autozone.
Not too bad. I may have too check into that. How hard is it too get to the PCV valve?
I do know i need too change both top and bottom radiator hoses, along with thermostat since ill be in that general area anyway.
This car sat for a year before i got it. most of the maintenance ive done too it has been just catching up lol. New tires, new starting system (starter, neutral safety switch), plugs, tie rod ends, etc.
I inherited the previous owners electrical f*** ups however... the original ignition cylinder wore out so he wired a new one in sloppily with the old one just dangling underneath the dash, essentially just piggybacked off the leads on the end.. as a result my sunroof hasnt worked since i got it
probably cause of a wire not connected.
