97 Altima gauge failure??
General discussion area for the U13-chassis Altima
seansr_08
Car: 97 Nissan Altima
I have been having my car for about a year now and had no problems with it. But suddenly my speedometer gauge would start to fail. It would rise and fall between 2-4k. But it wasnt really a priority because i knew my speed in 5th gear. But then my tachometer started doing the same thing. And now my engine temp gauge wont work at all! My fuel gauge is fine. But idk whats goin on!!
HELP PLEASE!!!
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Please clarify:
Your Speedo is bouncing between 2k-4k? Or do you mean you tach?
seansr_08
My tach did that when it was going out. It doesnt even move anymore
Rev_D21
And now the speedo is err'ing?
seansr_08
Yes and the temperature sensor. I have been doing some reasearch and i am convinced that the problem is with a fusible link... I just have to find where it is
Rev_D21
What makes you think it's a fusible link? I highly doubt it. No fusible link in the circuit at all plus it would effect more than just your gauges if it was a fusible link failing...psst they burn up, they don't intermittantly short out. I will gamble that your gauge cluster is dying or the connections on the back are not tight.
There's a schematic of your system in this link... http://www.nicoclub.com/FSM/Altima/1997/el.pdf
seansr_08
Well i was thinking back to what have caused this, and about a month before this happened i put a larger mass air flow sensor on. I forgot do disconnect the battery and one of the wires grounded out... and then all guages started to fail one by one..
Rev_D21
If it were a fusible link you'd have no power to the cluster because they burn up fast when over-amped. I'd suspect the cluster myself, it's delicate.
seansr_08
well i swaped clusters from another working altima and it still dont work, but i put a test light on the back of the connector and it only has power to the dummy lights..?
Rev_D21
Sounds like it's time to start tracing waires back to the fuse box.
seansr_08
Its been a little while. But i got a street bike for a daily driver so now i am going to change the whole wiring harness. I tried tracing wires back and forth. Its really frustrating. Anyways I will be putting my other wiring harness in soon. Just keeping yall up to date..
Return to “1st Generation Altima Sedan (1993-1997)”
