First you go to the j/y and get 97 altima fans (make sure u get the connection plugs )Then u go to any local autozone and buy a thermostat fan controler Then u have to trim a little the fans in both sidesAfter that u take out the engine fan ( make sure u keep it cuz u never know if u gonna use it again)Then u install the fans, and put it in place the only hole u have to do is in the long one the other one is g=ood and for the bottom use tiewrapThe a/c is easy u just plug it in the other one u follow the chartThen u istal the thermostat sensor then u place the thermo controller where is best for u Then u cover the harness with plastic cover and place it nice and nit That it!!!!!Just remember to set the fans and make sure the a/c fan come on after the other one ...
Modified by DRIFTKNIGHT_240 at 10:21 AM 4/24/2009
