Chrisfrend »
https://forums.nicoclub.com/chrisfrend-u12711.html
Wed Dec 29, 2004 7:00 pm
I finally got around to replacing all the bushings related to the new larger 24 mm. stabilizer bar. The upper bushings on the connecting rod to the lower arm had not been done. All the old bushings were very hard and dried out; my car had been in Texas for 7 years, which may have made them worse.
In any event, the new bushings were more flexible than were the old, and the ride quality is significantly better as a result. As Q45tech has pointed out, new bushings do make a big difference. However, the handling is not quite as crisp as it had been, although still a huge improvement over the stock Q45t bar. The result is probably a better balance for commuting and urban driving. I may eventually tighten the bushings a bit.
I had the bushings installed at an excellent local tramsmission shop where I was also finally getting my broken speed sensor replaced. The dealer wanted over $1,000, whereas this shop did it for $620. Fortunately, my after market warranty picked up all but $100 of this repair expense. Thanks to this board, I also had the rear main seal replaced at the same time.
