Aatrain »
https://forums.nicoclub.com/aatrain-u223931.html
Thu Aug 15, 2013 7:02 am
Mine did the same exact thing- it was indeed the relay, but it was hard to pinpoint bc sometimes it worked, sometimes not- seemed like every time I looked at that being the problem, it would straighten up and run right!
I would go to your nearest pick n pull and grab a handful of relays (I have bought bad ones) and try replacing that relay. One way that I could tell if a relay was good without having a meter: they're the same relay as the fuel pump relay on mine. So I would switch out the relay with the fuel pump relay and then turn on the key and see if I could hear the fuel pump spinning. If I could, i knew the relay was good. That's the way that I fixed mine, but I'm no mechanic.
