xekushnr »
https://forums.nicoclub.com/xekushnr-u16901.html
Thu Jan 31, 2008 7:33 am
If you dont have an FSM, buy one now. The O2 sensors act as a potentiometer of sorts, the voltage on the O2 sensors fluctuates with the reading. This voltage is what tells the ECU how much O2 is in the system. If you measure the voltage coming from the O2 sensor and compare your findings with the FSM, you can determine whether or not the sensor is in spec. Do this with the voltage setting, NOT the ohm setting. Measuring voltage doesnt hurt it, but sending voltage may.
