SlidnSideways »
https://forums.nicoclub.com/slidnsideways-u27106.html
Fri Nov 16, 2007 6:00 am
Im not sure what you are refering to when you ask about the condition of the cooling system. the mileage on the car is about 88k. Im not sure what mixture is in the car at the moment as I just bought it a couple months ago. Im planning on flushing out my system this weekend and applying the appropriate mixture.
The grinding noise, as I stated before, is for a very short period of time right after the engine is shut off (about 2 to 3 seconds) and only occurs if I let the car sit still and heat up past normal temps. Any other time I shut off the car when its not heated past normal there is no grind.
Im thinking bugs and grime in the radiator fins may not be the problem because that doesnt really come into account until after im moving correct? I may be wrong so please correct me if thats the case.
Im not sure what the cardboard test is but Ill search for that after this post.
Another question though... could this be a thermostat prob maybe? I mean the heat went from the highest it could go on the temp gauge to right back to normal almost as soon as I started moving. Im not sure but is it possible for the engine to cool down that fast after being so hot? Maybe the gauge is just misreading?
Ill let everyone know how the flush works incase anybody else has the problem later. If there are any other suggestions please let me know.
