shazzy »
https://forums.nicoclub.com/shazzy-u192576.html
Fri Oct 21, 2011 8:55 pm
*Changed the title to one that goes with the new topic*
Hey guys I just registered to this forum today for advice. I am looking at purchasing a 97 240sx I found for sale. I was talking to the guy, he said the car runs rough and doesn't hold an idle well. On his ad it says "Not sure if it's grasping for air or starving for fuel." After some research, I have come to find that it could be the fuel injectors, or the exhaust being clogged, vacuum lines, something on the intake like that MAF being bad. So I asked him if it threw any codes and he said that it needs an intake air temp sensor and the egr has been deleted. Do you guys think that the intake air temp sensor is the reason why it may be doing that? Also, he replaced the Head Gasket, Head Bolts with ARP Bolts, Water pump, Spark Plugs, thermostat and replaced the Clutch Master Cylinder and Slave cylinder last year. I am going to look at the car tomorrow around 12-1. This will be my first 240sx so that's why I am asking for what the cause could be. Hoping to make a good daily driver out of it with boost plans later on. Thanks.
shazzy on Tue Oct 25, 2011 8:30 pm, edited 1 time in total.
