Bronze MFP »
https://forums.nicoclub.com/bronze-mfp-u7726.html
Fri Jan 19, 2007 2:28 am
if you're just trying to replace the bulb there should be a hard rubber/plastic domed out piece on the rear of the fog light that should screw off. It might be a pain to get off the first time, but the foglight bulb should be behind that. again i've only dealt with zenki fog lights, but I can't imagine the kouki's would be that different. once inside, there should be a metal clip that should pop off on one side and is hinged on the other so you can swing it out of the way. after that just pull the bulb out, disconnect the power cable and replace.
