SlidnSideways »
https://forums.nicoclub.com/slidnsideways-u27106.html
Mon Feb 04, 2008 3:18 am
Nothing in my setup has been changed. Ive had this setup for a while. i used it in my 89 240 then put it in my 92 and its now been in my 97 for about a year and a half. I didnt have this problem with the 2 cars before and didnt have it with this car until around a few months ago.
Im not sure how hot the amp is getting... Im not very knowledgeable about these things. Is there some sort of way to test this or am I just feeling it to see? Upon touch, it doesnt seem to be to warm.
Yes, it is the regular charging system. Ill check the things previously posted and get back to you on that.
Also, (and I probably should have mentioned this before...sorry) I played around with the fade and balance settings before and after my subs seemed to lose power. It seems when the bass gets softer, im losing a sub. I set the speaker settings so that its all the way to the rear and to the passenger side, and the bass is still there. When I set it to the rear driver side, there is absolutely no bass at all.
