97 240sx 5 Speed Swap
HasNoTiresLeft
Car: 97 Nissan S14.5
Hey just finished up my 5 speed swap but as im waiting for my driveshaft i started to test things out. I bled the clutch lines till there was no air bubling, and started to get a decent pedal feel (No dampner btw)
Only problem is, When i press the clutch pedal in all the way shouldnt the output shaft stop spining? The clutch fork is moving back and forth when you pump the pedal, but it doesnt seem to disengage the clutch. Is the shaft only spining because there is no load on it? (No driveshaft)
I have the transmission installed, but no fluid in it. Its a new flywheel from nissan, with a centerforce Stage 2 Clutch and Pressure Plate.
Any help on this would be greatly appreciated
240burnedyou
Sorry i cant answer your question but i was hopeing you could answer my question lol, i jsut got my first 240 its a 93 automatic and i was wondering how much manual trannys sell for along with the clutch pedal and lines. Thanks
180fan
Car: 89 fastback
Is the throwout bearing properly seated on the carrier and is the fork on the carrier properly?
