Peeple »
https://forums.nicoclub.com/peeple-u203062.html
Thu Apr 19, 2012 12:40 pm
I've been trying to diagnose a starting issue for a couple days now and have worked through the easier possibilities I've found on this forum. Now I need help going forward.
The problem is intermittent, about every fourth or so turn of the key the car starts fine with no extra cranking. But when it doesn't start there is nothing, no click of the solenoid, no weak winding noise, no cranking, zip.
Starter = Fine
Clutch Switch = Fine
Fuse = Fine
Battery = Fine
Behavior outside of my knowledge: When I put the key in the ignition and click it forward one position, with all accessories off, I'm hearing whirring, sounds like it is from the starter.
Possible other contributing factors: I have a slow oil leak on my front main or timing cover, it has whipped oil on to my alternator. Would this be a contributing factor?
Grounding is a possibility. Where are the grounding points in a 97 240sx? It has been the better part of 7 or 10 years since I've had to deal with a grounding or electrical issue. Please be specific in your instructions. Thanks for any help.
