Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Mon Oct 06, 2008 12:59 pm
T3 had a interesting case where 2 previous shops [dealers] had changed fuel pump, filter, lines, regulartors , fuel pump again , controller again on a 1997 Q with little success.
Byron found the bypass resistor burned along with its wiring resulting in low idle and cruise fuel pressure [<15 psi] which became normal under acceleration and WOT.
