Postby
grunze »
https://forums.nicoclub.com/grunze-u4347.htmlMon Jan 14, 2008 6:43 am
We have serious slipping on turns. The plan is to have our mechanic tear down the rear end, determine parts needs, order from Scottsdale, and then install new parts. If anyone has any advice please let me know. Thanks.
Postby
Q45tech »
https://forums.nicoclub.com/q45tech-u112.htmlMon Jan 14, 2008 7:09 am
Failure to use oem soft tires is the usual problem. Tire Treadwear index should not exceed 200 reference units!
Hard to find tires soft enough and fast wearing enough to meet oem design..........11 years later.
Rear shocks wear faster than front due to need for higher rebound stiffness, so called expansion rate. Rear shocks are noticeably reboundless after 60k and 4 years of typical use.
