96q knock sensors
maxwell867
Car: 1996 q45
For a while i have been getting poor gas mileage and problem with poor acceleration. I've cleaned MAS and still no improvement. Finally i hooked up code reader and got a code for knock sensor bank 1. I've searched for a writeup on replacement of knock sensors but only found one for a 97y33. Is the process basically the same or is there another writeup for the G50. What other parts besides the knock sensors and harness should i change?
Thanks in advance.
96Qowner
Car: 1996 Q45
To get to the knock sensors, you pretty much have to remove the plenum, which opens another can of worms, because you'll probably have to destroy some hoses that are brittle from heat and age. Big job. Here's a writeup from an earlier thread:
zerothread?id=142590
You might want to consider replacing ALL the hoses while you're in there. Here's a current thread by someone who's doing it now:
zerothread?id=245231
qship96
Car: 1996 Infiniti Q45
funny,my 96 recently threw the dreaded knock sensor code and I notice NO change in acceleration,either part or full throttle?
Q45tech
Some people are sensitive and some are not.....................a few tenths even half of a second is hard to resolve................yet that would represent 30-50 HP.
maxwell867
Car: 1996 q45
96Qowner wrote:To get to the knock sensors, you pretty much have to remove the plenum, which opens another can of worms, because you'll probably have to destroy some hoses that are brittle from heat and age. Big job. Here's a writeup from an earlier thread:
Thanks for all the info. I may be starting this project next weekend depending on when i get sensors and plenum kit from joe. Looks like alot of tedious work but i'd rather do it myself .
