96q headlamp bulbs replaced
qship96
Car: 1996 Infiniti Q45
I had a burnt out bulb and today replaced the bulbs with piaa super extreme whites! Wow,the foglamps look yellow compared to the crisp white look of the headlamps now!What a pain this job is,no room to work around!Anyone else try these bulbs? How about for the fogs?How hard are THEY to relamp?
EWT
qship96 wrote:I had a burnt out bulb and today replaced the bulbs with piaa super extreme whites! Wow,the foglamps look yellow compared to the crisp white look of the headlamps now!What a pain this job is,no room to work around!Anyone else try these bulbs? How about for the fogs?How hard are THEY to relamp?
The foglights use a H3 bulb which should be easy to find in your favorite plasma blue super extreme hyper white bulbs. The headlight bulbs are easy to replace if you pull the headlight out, which requires taking off 4 bolts.
