Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri Jun 01, 2007 12:43 pm
Nice to see that the Michelin 235 outlasted the others by 50%.
Kind of like truth in lending laws............Michelins Name and reputation.
Plus the stronger higher load index of the 235.
If one doesn't keep up with upperlink, tension rod replacement and alignments twice per year the results are obvious.
Same with inflations 35 psi cold minimum.
Still running the last of 235 on the front and I have gotten 35,000 miles plus out of the last 3 sets..............exactly 4 new one on at 201,000 miles, now at 314,000 so 113k/3=37.5k average some more some less.
I sure won't quibble about 10% less than warranty.
Unfortunately no 235 available so you will have to accept less, on a Q always assume 1/2 warranty is good with non Michelin tires.
Michelin Pilot Exalto A/S in 215 [just under $100] or 225 would be the best bet.
