kevin43734 »
https://forums.nicoclub.com/kevin43734-u286219.html
Thu Oct 25, 2018 8:57 pm
Background: I have acquired a z32 and it is a 1996 with a early style TT motor. The ECU that came with it was a 1996 TT Auto, where as I have a manual transmission. I was getting a fuel smell in the engine bay and tracked down the smell to the injectors(stock) and pulled the plenum and replaced the o-rings and never could get it to run right (fuel smell went away). That was a year ago and it sat until recently. I figured out one or more of the injectors were stuck open and dumping a ton of fuel so I replaced the injectors. The car came with a JWT 1996 ECU tuned for Dual POP Chargers(DCP) and 615cc Nismo injectors in the back seat so I thought why not go ahead and replace the injectors with the 615's and hook up the JWT ECU. I completed the swap, calibrated the new TPS (long story), and fixed the couple of vacuum leaks I found. When I fixed the last vacuum leak, the engine went from idling at 1000rpms to dead. Restarted and idle is surging but it will run. Started trouble shooting the PTU and CAS and found some of the connectors are shorting but no matter what I do I cant get it to run correctly.
When I purchased the injectors I thought the ECU was for a single pop charger. I now realize that idle issue is almost certainly because the JWT ECU has the injector size cut in half and I'm still running 1 air intake. I just want to make sure I'm on the right track here before I go and buy the dual pop set up?
One more note to confirm my theory here. Spark is good, compression is good, and injectors are great as per an ohm test, and listening to them click away with a stethoscope. The engine will also not run above 3000 RPMS in neutral; however, if I switch ECU's back to the original tuned for stock injectors it still runs like crap at idle surging and what not but I can achieve RPMS past 3000. This to me seems like the smoking gun.
So my thought is I'm going to order new harness connectors for CAS and PTU, a consult Z cable, and the dual pop kit with the selien translator (use average setting). I just can't imagine the car ever running correctly with a single pop charger and a tunned ECU for Dual Pop.
Stock turbos with boost controller (10 psi).....shouldn't have any affect at idle.
