I found the transmission specs in the thread below. According the info, the 93 is no different from the 90-92. I am aware that there were some changes in the 91 that I want to avoid. The problem is, how do I tell the years apart? Are there any markings or codes on the transmission to ID the year it was built (if so, where?) or are they all pretty much stamped the same... eg: "RE4R03A".
zerothread?id=25414
Transmission: 90-93
RE4R03A 51x65 transmission 4 speed autoGear Ratio1st 2.784:12nd 1.544:13rd 1.000:14th 0.694:1R200V viscous limited slip differentialFinal Drive Ratio: 3.54:1
94-96
RE4R03A 51x79 transmission4 speed autoGear Ratio1st 2.569:12nd 1.479:13rd 1.000:14th 0.694:1R200V viscous limited slip differentialFinal Drive Ratio: 3.54:1
