96 Sentra 1.6L Automatic - idling too high
jimbaker
Car: 1996 Nissan Sentra
My car is idling fast on cold starts and takes several minutes for RPMs to drop low enough to shift into drive. What do you think is wrong and how can you fix it ?
ahardb0dy
Car: 1990 Nissan Sentra, 1994 Pathfinder Se, formerly owned: 2005 Nissan Titan, 1994 Infiniti Q45t, 1987 Nissan Hardbody SE-V6 4x4, 1980 Datsun 310GX
The engine should idle higher when first started and than lower as the engine warms up, is this something it never did before? In colder climates, (didn't notice where you were from) it may take longer for the rpm's to drop to a normal idle.
Anonymyz
Car: 1996 Nissan 200sx - GA16DE
Blip the throttle a few times and that will drop the RPM's. Its basically running at a higher rpm to allow the engine to warm up. I live in California and mine does the same thing. Its completely normal
