VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Sun Jun 06, 2021 5:34 pm
Slick workaround! If you popped open that master switch you'd find a goofball two-coil multi-pole relay that has NC throws leading to the passenger window. Your actual problem is probably in there. Because it's a series circuit, when they fail closed instead of open they can even make the passenger side switch operate backwards. It always sort of peeved me that Nissan didn't just use two smaller relays, then the circuit boards could be easily reworked. But that's a great circumvention, thanks for sharing it.
