So I have been searching for awhile and got some pretty good info on my question, Just not enough info so im hoping here is where my seach stops
I picked up a 96 shell, No engine trans or wiring harness your basic roller..It has been next to impossible to find obd2 parts for the car, I have a complete kade swap obd1 out of s13 I used to have.. Engine, Trans, Harness, ecu...Can I use my entire obd1 swap for the car? From what I have searched Ive seen its possible as long as its all obd1, If thats true and I can convert to obd1 what about the Chassis harness?. Is there any crazy extra work involed in doing this or will it be a not to hard plug and play type swap? I dont have emissions so Im not worried there, Biggest questions are about chassis wiring and will everything run ok with a obd1 setup?
Would love to get some tips and info from anyone who has done this..Thank you
