fj4072 »
https://forums.nicoclub.com/fj4072-u286196.html
Wed Jun 19, 2019 10:56 am
Been trying to add refrigerant, can't get it to accept more, blowing hot air out of the vents. Everything is working, clutch engages and cycles normally now after replacing the relay. Even brought it to a shop, they couldn't add either, says there may be a plug up somewhere. Any ideas? I'm using AC Pro can, needle stays in the red. Shop hooked up gauges, said looked ok, no leaks.
