RustyBucket »
https://forums.nicoclub.com/rustybucket-u150577.html
Sat Nov 13, 2010 6:39 pm
I'd say check the simple tings first:
Is your Power Steering fluid low? There is a dipstick built into the cap of the reservoir on the P/S pump. The P/S pump is found on the lefthand side of the car just behind the air box.
What is the condition of the belt that drives the P/S pump? How is the tension?
If those things are OK, then I'd recommend checking the lines and the steering rack for leaks. Hopefully it isn't something as bad a s a new power steering pump.
