96 Q45 with 91-93 transmission
Twin96Q45
Car: 94 Acura Legend, Twin 96 Q45s, 99 LX470, 03 MB E500
Hi,My 96 Q45 transmission went out at around 188k. Was running strong but the clutches worn out first on the reverse and then 1st gear. I made a big mistake by replace it with a used 91-93 one. Now it always go the limp mode after a few minutes. Is it the TCU or something else? I had switched the TCU with my other 96 Q45 but it 's the same problem. Do I need a 91-93 TCU? Does it fit with the 96 wiring harness?Thanks
93 Q45
Car: 93 INFINITI Q 45
i just went through this with my 93 and no they dont interchange91 92 same 93 its own little bast---d 94 to 97 same so it sound like you messed up call a local salvage yard they will have more specific info all i know is my trans was a real bear to find i could find atrans for 94 plus all day
rsiwicki
Car: 95 Q45T
You 2 guys are certainly the first to say that a you can't interchange years of transmission's with the year of the car. Your transmission is either installed incorrectly or the replacement is broke also. Do a search and read the posts, there are about 10 of us now that have several thousand miles and many years with the 90-93 transmission into a 94-96 Q. The gearing is different so you will need a 90-93 TCU to match up the shift points if you want it to be exact otherwise it will shift a few hundred rpms different. I have put over 30,000 hard miles on mine without a problem when I installed a 92 transmission into my 95 Q and I used both the 95 and a 93 TCU.
