Q451990 wrote:
to NICO!
I would start by pulling the pan on the transmission and replacing the "filter" screen assembly. If it's clogged with old clutch material and stuff, it can cause all kinds of issues. There is also a transmission self diagnostic that you can run that will tell you the condition of the electronics in the unit... check out the factory service manual here at
http://www.nicoclub.com/FSM/
All of that said, if the transmission was empty when you bought it... chances are pretty good that it's been abused beyond repair.
Good luck!
Heath
To Heath's point, there may be clogged ATF filter under the hood also. The filter located is in the battery area under the hood.
The OEM filters are quite expensive and only available from a dealer. You can try using an aftermarket filter, or just for
"diagnostic purposes only" try bypassing the filter to see if it makes a difference, then once have ruled out a clogged external filter is contributing to the problem, quickly replace it with a Magnafine or OEM type. If the under the hood filter has clogged, it can starve the transmission for needed fluid circulation.
Here's a picture of a filter for a 94-96 model below. Note: My 91 Q uses a transmission and radiator from a (Phase II) 94-96 model with the dual cooling lines in the picuture.
