96 Q45 trans swap- '96 TT300Z or NA 300z trans work?
johnnyrotten
Car: 1996 Q45
2003 Maxima GLE
1993 Ford F250 Diesel
1973 240z w/L28 Turbo engine
picked up a sweet 96 q and the trans is acting up. have accesws to numerous 300z parts ans transmissions. will any z trans swap in? any help is appreciated.
Q-ZILLA
Car: 1995 Infiniti Q45t
Rear Mount Turbo
R.S. Enthalpy Tuned on
Dynojet-5000lb roller
453hp/453lbft
2008 Nissan Armada
2009 G37 Convertible - SOLD
2004 Cad. Escalade POS - RIP
I was looking for you while doing a gear swap on my Q... Put 4.11's from an R33 out of Australia. The early Z32TT uses the RE4R03A 51×79 transmission. OOPS, It was Johnny Rocket, but the info on the transmission is correct.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Look for info on my Z32 trans swap. Doable with lots of work an an adapter. NA and TT trans are the same internally.
Q-ZILLA
Rear Mount Turbo
453hp/453lbft
2008 Nissan Armada
elwesso wrote:Look for info on my Z32 trans swap. Doable with lots of work an an adapter. NA and TT trans are the same internally.
Wes... Roughly how many hours and cost to go 5-speed? I should just go with launch control, but God, I do miss a clutch... BTW; I renamed My Baby, what do you think? Scroll up... lol
IThaJ0kaI
Car: 96 G50, 90 S13 hatch
250 for z32 trans or 400ish for z33 trans
400 for adapter plate
70 for machine work on bellhousing
100 flywheel
399 for a spec stage 3 clutch
150 for shorter shifter bracket
179.99 for driveshaft mod
~50-75 for a trans bracket for the z32 or use the stock one for z33
Time isnt too long, I pulled my engine but it shouldn't be too hard keeping it in.
Q-ZILLA
Rear Mount Turbo
453hp/453lbft
2008 Nissan Armada
Tempting... Maybe down the road. I have a few other small things and paint, which isn't going to be cheap...
