bluefeyd »
https://forums.nicoclub.com/bluefeyd-u37690.html
Mon Sep 17, 2012 3:53 pm
Well I ran a few of the continuity tests from the service manual, but not the ones to/from the ECM, because I have not yet taken off the glove box and accessed it before. The checks of connectors to ground and voltage all came out sat. Since I had recently changed the CPS with a new part (my MAF replacement was used, but it was not throwing a code), I posited that maybe there was a common link to the faults and proceeded to thoroughly clean the engine grounds (from the illustration in the service manual). Put it back together (there is a plate that you need to remove to get to the second of the two ground screws) and took it for a road test, with both in town and hwy driving. Almost shudder free, just a few hiccups at low speed shortly after starting. Also the bug where TCS off and SLIP were locked in has cleared. I can turn TCS on and off with the switch just like normal. Idle is coming in a little low ~550 rpm so I am considering adjusting that set screw (again using the procedure from the service manual). The check engine light is still in, and Autozone confirms that the codes are still in (they aren't supposed to clear them, but a shady one has been known to do it for ya). Looking to clear the codes, neg battery terminal didn't do it. The positive one is a pain to disconnect, but I will probably try it next.
