96 Q45 knock sensor
mrlambert
Car: 96 q 45
can anyone send me pixs & instructions on this process i have just ordered 2 new sensors, my car has been running bad for a month & my code read knock sensors bad
thanks
Rex
Car: None
If you didn't get them, try to add the harnesses to your order.
Not sure if there's a How To, for this repair. Try searching here and Infiniti Online Mechanic both recent and archived posts.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Since the KS are at the very bottom of the valley, best to reasearch the under plenum hose job in IOM. You will probably have to replace your hoses, VC gaskets and maybe plugs anyway as it is best done at once.
You must replace KS harness when you do.
