dubs96q45 »
https://forums.nicoclub.com/dubs96q45-u59873.html
Sat Feb 07, 2009 3:52 pm
I have searched the old threads and have been unable to find any posts that address my specific situation, so I apologize if I missed it somehow.
So here is my situation:
My California registration renewal required me to get a Smog Check for my 96 Q45. I took it to the nearest Check-only station, and before officially starting the test, the tech plugged a hand-held diagnostic device into my ECU. At this point the tech told me that I was showing a knock sensor code, he not any more specific than that. He did not complete the test because he told me that it would automatically fail, and that I was better off getting it fixed first(he was obviously not the owner).
I was quoted about $800 by Jerry Tucker's All Import shop down here in San Diego, which I didn't exactly have, so I began investigating other options. I came to the conclusion that my immediate solution was to get it tested and have it fail to get my registration renewed, and deal with the DMV. I was attempting to find a shop that also did repairs in hopes that I would be able to avoid paying for the smog check twice. After driving to and receiving bad info from no less than 6 shops, I finally called Hillcrest Auto. I was informed by the younger girl who I spoke to(no offense, just a little ironic), that Nissan/Infiniti of this era have a knock sensor code issue and as long as my check engine light is not on, it should not cause a problem with the smog check, due to the fact that this glitch is exempted by the CA Bureau of Auto Repair. I took it to the shop she referred me to, and it passed no problem(I will be going there from now on).
First of all, since I didn't find anything on here about this situation, I thought it was worth posting my experience so others don't go through all the hassle I have trying to get this issue resolved, only to find that it wasn't an issue at all.
Secondly, I was wondering if even though it doesn't present a smog check issue, and i have not had a noticeable change in MPG or performance, is there any reason to think that this could still be causing damage to my engine? I noticed a bunch of posts talking about a need to change the knock sensor and it associated components eventually, but I was unable to determine if this is one of those situations. Any info would be much appreciated.
My Q has 136k mi. approx., and prior to me the only other owner was my father, who took exceptional care of the car. I believe that the fact that after 2 years and 10,000 mi. and no maint. other that oil changes is evidence of this. He drives like an old lady anyway and this was his baby.
I apologize for the long post, but I hope it will save someone else from going thru the same hassle I have.
Thanks!
