'96 Q45...how is the rear side marker lamp r/r'd?
chuckphx
Car: 1996 Q45
I have a bad bulb in the driver side rear side marker lamp. how do you remove / replace this thing? cant figure out how to get to it.
Please advise.
qship96
Car: 1996 Infiniti Q45
Cant recall off hand, but instructions are in the owners manual!
chuckphx
Car: 1996 Q45
I could not locate the directions in the manual. Looked under body/trim, electrical and maint.
Any help would be appreciated.
goody90q45
Car: 1992 Infiniti Q45 (sold)
chuckphx wrote:...how do you remove / replace this thing? cant figure out how to get to it.
Pry the whole assembly forward with a small screwdriver between the lens and the chassis.
Q451990
Check page 7-30 in your owner's manual (not the FSM). If you don't have your OM, check here http://72.3.186.204/deptog.aspx?dept_id=54
Good luck!
Heath
chuckphx
Car: 1996 Q45
Thank you. Got it done. The left side turn signal goes double or triple time that the right side blinks...the bulbs still work though...could there be a relay i need to replace?
unknown007
Car: White 1993 Q45 (G50)
Most likely sometimes its a fuse but could be a relay.
