The quick rundown... I was driving in heavy fog and hit a grocery cart right front side and it broke the headlight cover, completely shatter the corner and damaged the fender.
96 infiniti q45
Problems that occured.
High beams are stuck on constantly when i turn the headlights to on.The high beam indicater light is constantly in lowbeam mode. And i have no illumination in the car (no trim or dash lights)
I read that its the headlight relay or a relay that could of popped according to another thread
high-beams-only-after-accident-95-q45-t405307.html
But I cant find the headlight relay on mine, I did just re read it and it could say illumination relay so ill go back to search for that.
My tail lights are in working order no problem there
Though my high beams are stuck on when i turn on the headlights the low beams are functioning as well just with the high beams so i may just end up unplugging the high beams until i find a solution to this.
Any help would be appreciated
I am also looking for a passenger headlight corner and gold fender
